Hey guys
I did my data backup on my kitkat 4.4.4 and when I update to lollipop 5.0.2 my backup didnt work because incompatible software version..
So.. PLEASE help me..!!
It doesn't work, there's not much we can do, sorry.
I had the very same message when I updated my Xperia Z1 to lollipop.
Did you wipe before you upgraded? Did you save the backup to your SD Card or did you back up using PC Companion?
The only thing I can think that would work is using Flashtool and a 4.4.4 ftf file to downgrade to 4.4.4, restore your apps, take the 5.0 upgrade again, then backup the apps whilst on 5.0.
