Hello and welcome to AndroidForums.com. I have seen this issues with other devices as well and it is usually a problem with the wi-fi router that you are connecting to.
I would start by power cycling your wireless router and see if you still have the same problem. If your router is dual-band, I would try to connect on the G band. I hope this helps point you in the right direction.
