resistingarrest
I use my SW-X96 Android 6.0.1 TV box to stream 4k video from my windows 7 computer. I noticed something when i streamed a 80mbps 4k sample file that it lagged alot on the TV. It turns out it can't stream the file faster than 50mbps to the android device. The android device was advertised as a 100mbps device, so it should be able to stream twice as fast.
I think the problem is that the Android TV box has its ethernet configuration set to a half-duplex negotiation. So i tried configuring it using ifconfig (rooted and installed busybox); ifconfig eth0 media 100baseTX mediaopt full-duplex
But i get an error saying it doesn't know what 'media' means or something.
How can i tell my android device to use full duplex negotiation? And is that even what's causing the slow download speeds?
Thanks.
Thanks.
