My first smart phone
jstout
And Im to dumb to uninstall the app notepad inkpad, tried the free version and dont really care for it, so woulld like it gone.
I would appreciate some advice from some of you more knowledgeable folks
Thanks In Advance & good luck.
jstout
PS.......... It is the Motorola Bionic, thanks again.
Go to settings/applications/manage applications, scroll down to the app in question, and click on it, then uninstall. And don't call yourself dumb. My Inspire came with a setup guide, but no instruction manual. I had to slowly figure things out. You will too.
Samsung infuse didnt come with any instructions either... Just plug in.. Insert sim card.. Turn on..
jstout
and just so you know, you should be able to uninstall it right from your app drawer, just long press on it, drag it down to the trash but don't let go right away, hold it until it turns red and pops up with "drop to uninstall." I find this is a little bit easier and quicker than having to go into your settings.
you can also uninstall it from the market as well.
if we talk about smartphone - it is LG P970 (optimus black)
if just mobile phone - sony ericsson, don't remember model
