J Justjack22 Lurker Jun 6, 2018 #1 My G6 doesn't see either of my micro SD cardsbwhen I put them in. Any ideas?
A bochur Android Enthusiast Jun 6, 2018 #2 Do the sd cards work in other devices? Have you tried restarting your phone after inserting the sd card?
lunatic59 Moderati ergo sum Moderator Jun 6, 2018 #3 Do you know how the cards are formatted? If they are NTFS, then the phone won't see them.
jefinjose007 Lurker Jun 8, 2018 #4 Try formatting using a laptop... there's options to change the type of format
