Remove the battery for 5 minutes. Put the battery back in. Hold down power and volume down for 30 seconds. If that turns it on tap the back buttons until the android shows up. This will do a full factory reset.
If you can't get it to do anything, your hardware is messed up. Take it back to where you got it from and they will replace or repair your device.
