Root My mods/theming for BH_man 1.6 R8
thegame3202
Alright, so I'm doing minor customizing in my free time. Just doing simple stuff as I'm just learning but here is a screenshot of what I've done so far.
1) battery icon changed
2) drawer/app handle changed
I can customize the drawer handle to anything you guys want if everyone wants the same thing. Here's a screen cap, I'll upload the files if someone wants them.
Yeah definately, just needs to have 7 possible images, and another set for when it's charging. Unless you just want it the same all the time.
Also, can change the title bar background where the clock is located. Not 100% sure how to change font colors though, but I'm pretty sure. I'm working on un-rounding the corners right now, from the background
Good work but as far as the drawer handle goes I would say the original one was fine because it was simple and elegant imo with the right theme. you know the triangle?
Yeah, it wasn't bad. Just like playing around :-P But why the hell do I randomly get "protocol failure" from pushing shit? Then my device is offline?... I type everything in right.
Alrighty, so I got the round edges removed, does anyone want me to upload the orignal files, with the square edges? Without battery mod and drawer logo?
Ah crap, I need the original Launcher.apk, can someone upload that plz?
do: adb pull /system/app/Launcher.apk Launcher.apk
It should put the file in the folder you're running adb from. I changed the icons in mine and didn't save the original :-\
I probably could but since I'm not using that version, it makes it a little harder as I don't know how to pull apart the files in ODIN files.
Also, I remember seeing someone ask about a thumbprint to open to apps screen, I am working on that now. Should be done in just a few, but prolly won't have time to post until later tonight if anyone wants it. Only thing is I will only have the files I am using, so you would have the square background, the battery mod, and the thumbprint. If you guys want it, I'll gladly up it. I'll take another screen cap when it's done
Can you send me the Battery Icon's for the Frameworks-res.apk
Would love to include this in the 1.6 No Twiz I'm about to Release...
Yeah BH Man, the only diff with those is it says the percent within the circle. I just found those the other day and thought about switching. Let me know if you want mine and I'll gladly send them.
@behold_this: This file is from the BH_man galaxy 1.6 R8, and it's a framework file. The icons themselves can be inserted into any platform (if the person knows how to do it). The files I'm posting are for galaxy 1.6. Only tested on r8
What?
http://androidforums.com/535102-post1.html
Has 0 to 100
http://androidforums.com/539996-post9.html
Is just the Circle :D
This is the version uploaded in this post.
http://rapidshare.com/files/376423465/Current.zip
commands to run in adb:
adb push Launcher.apk /system/app
adb push framework-res.apk /system/framework
Let me know if you have any issues! Hope you like!
EDIT: Don't know why that screenshot is off center, doesn't look like that on the phone. Also, the weather in the notification bar is not in here, it's the weatherbug app. Not responsible if this wrecks your phone (mine is working just fine, just need to put this in here) :-)
