Hello There!!
I was trying to get back to stock rom
And Always Getting this no space error 5069 While Flashing
After searching i found that format will fix this and i can flash like a charm
But after formatting my Device Is dead
no boot, no charging, no recovery
I'm Trying TO whole flash but I'm there is no option for that only Getting without bootloader one
Then i've checked it memory in memory test option now i'm getting
Nand Flash Not Detected
Plz!!! tell me what i can do to take my phone back to life
The Phone is out of warrenty
Phone: Micromax a120 canvas 2 colours
Chipset: mtk 6582
When I try these things
1) after format+download it says no space error
2)then i tried firmware upgrade i'm getting " Failed to get PMT info " and "Invalid partition table" error in spft v3.xx
The Rom is original stock and needrom one
So the rom is not an issue
Plz!! HElp guys , many people are facing this problem not a single fix they got till now
If it works it will be life savior for them too
Chipset: mtk 6582
