My Phone Keeps Restarting Every 2 Minutes.
  • Start date Start date
A
Android Question
Guest
I have a htc evo and out of no where its starting to restart and just turn on and off. This already happened to me with my galaxy s2 so i had to use a phone my dad was using which is this one now its doing the same thing. its really starting to get annoying. HELP!
You could have a loose battery connection. Check the fit of the battery. This has been the cause of spontaneous reboots on several phones.
Fixes range from battery replacement to simply wedging a piece of paper in the battery pocket/compartment to tighten up the fit.
