my phone keeps turning of and on
  • Start date Start date
A
Android Question
Guest
ok so my phone keeps turning off and on not like completely off . but it keeps doing that and s it so annoying . ohh an di lost my sim card for the 4g so it only works on wifi andi hope thats not why thx
You can get another SIM card - just go to the carrier's store. (They're anywhere from free to cheap.)
As far as the phone turning on and off, it's most likely not the SIM card. Plug the charger in, make sure the phone is charging and leave it alone overnight. Then see if it stays on.
