Root My Samsung Ace crashed while installing Jelly Blast JB 4.1.1 Custom ROM For Ace 5830i 4m ANDROTWEET
Hi Team ,
I desperately need ur help here .
I have Samsung Ace s5830 . I have rooted and ran CWM from ANDROTWEET forums ..
Later while upgrading OS from 2.3.6 to JB 4.1.1 Custom ROM via the same website , I have rebooted the device after installation and it stuck at the reboot screen leaving the mobile turned ON ( the led on screen glows ) but nothing pops out ..
I have reseated the battery and ran the steps again -which are of no use.
Now I am unable to do anything on my phone ..
the below are the links
http://www.androtweet.com/2013/03/jelly-blast-jb-411-custom-rom-for-ace.html
http://www.androtweet.com/2013/04/install-root-and-cwm-recovery-for-ace.html
Could u pls help me in getting my Phone back with 2.3.6 ..
Cheers,
Waseem
Try flashing the rom again, and this time follow these steps
1. Wipe cache partition and factory reset.
2. In advanced>wipe dalvik cache
3. Go to format and mount options> format /system,/data and /cache, also mount /system and /data.
4.Flash the zip file.
This is the standard way of flashing the rom, skipping these steps may lead you to improper flashes. Some developers even recommend wiping cache and dalvik cache after rom installation. But this is the basic way of flashing rom.
And when you try to flash a rom next time, don't get the rom and instructions from a blog, always refer to a discussion forum where you can talk to people who have already flashed this rom and can guide you. The best place would be xda because that's where most of the roms are released and the developer is available to solve your problems himself.
http://forum.xda-developers.com/showthread.php?t=1976674&highlight=jellyblast
As a person who has rooted his phone and is using custom roms, you should always know how to use Odin and get back to your stock firmware. Look into that as a last resort.
