D dee11 Newbie Jul 22, 2018 #2 dee11 said: My T-Mobile LG G6 Hotspot won't turn on. Click to expand... Why is this happening ?
chocbar31 Lurker Jul 30, 2018 #4 dee11 said: Why is this happening ? Click to expand... You may have to reset network settings. Mine wouldn't turn on after the Oreo update. It's fine after the reset. Tutorial: The tutorial just walks you through the reset, and nothing complicated or spectacular. Hope it helps.
