ajdroidx
Android Expert
So, I have had the device a little over a week and the long and short, I am a bit conflicted over the thing.
First some background.
My daily driver for the most part has been a galaxy note 2 from AT&T, one device I have had issues with from pretty much the get go, I feel the multi window was misrepresented to me, well, I suspect I just misunderstood it, but I was sold on the thing being able to run two different apps side by side. My thinking was: wow, I can run a radar app and twitter together! Well, this is was not case.
I figured root and custom rom would fix those issues, and this ended up a large fiasco that has given me a headache since I decided to root, but enough of this type of talk.
The note II offered a large screen and large battery and since I work in a place where my signal is all over the place, mostly in the toilet, I can sometimes barely get a text message sent or received. So, its a good thing for the large battery. Not only that, the battery can be swapped. Indeed, I have a spare in case I forget to put the thing on to charge early in the morning.
So, with my need to tinker, and make the device more mine, the samsung was really not my friend. Sure, I could do somethings with it, but it was met with resistance. I got tired of needing to change the settings for my choice of keyboard every time I needed a reboot, the stock sammy keyboard sucks. Okay, minor annoyance.
Software updates, still waiting for 4.2. the blasted thing is still on 4.1.2. The only updates I see are a couple minor ones and the bloat gets updates. A lot of updates and I don't even use this garbage.
So, its looking like the Nexus 5 will fill the bill.
I ordered the black 32gb version. When I got it, I removed the sim card from my note II and inserted it into the nexus. No issues doing this.
Right off the bat, I pretty much knew what I was getting into with the device. Smaller screen, higher resolution screen, smaller battery and a camera that, well, I guess is better then nothing, but the software running the camera. Its more click and wait, even more so in HDR+ mode. Speaking of HDR+ mode, I have bought a camera app called HDR+, but it don't run on the device. Got one shot off, hit the settings menu as the image was processing so I can make changes, and it did not do anything. The second shot, the app force closed, so it could be a compatibility issue right now.
Still, the camera does work in a pinch.
Battery life? Well, I also have a USB myCharger stick (2000) and do carry the phones charging cable as well at work. Have not needed either, yet, but I don't use the phone too often. A couple days it cut real close and was in the red by the time my shift was over. Again, I suspected this due to the smaller battery and crap signal at work. It does make me kind of conservative on the usage however.
The device seems snappy, responsive. The scrolling is nice, the glass is really smooth. I like the grippy back, real nice step up from the slick Note II, however, it does seem to "snag" in my pocket when trying to put the device back in.
With the screen being a bit smaller, I do find the keyboard a bit cramped and awkward to type on. The keyboard is also in a slightly different spot due to the soft keys. I feel I can type faster on the note II, but I am used to it.
Volume. Kind of disappointed here. I suppose there is some sort of volume limiter here. My note II and III had this (the III I could click "remember this" and get rid of it) where it would warn me about high volumes. But it would go louder. The Nexus 5 don't. The volume in head phones (and high decibel output ones at that) is rather weak. I guess this is to keep me from blowing my ears out with high volumes, but some albums are rather quieter and could stand to be a bit louder. Not a huge issue here.
The ring tones suck. I cannot hear notifications most of the time. At least with my note II I could at least catch most of them. The nexus 5 at work in my pocket? Easily drowned out by the ambient noise around the job.
Call quality did seem decent, but I don't make many calls.
Overall, what I see here, what I experienced so far is "average".
I had a Galaxy nexus on verizon when it came out. I found the thing utter garbage. This new nexus 5. I find average. Probably what the Gnex should have been.
So, there you have it. I find the new Nexus 5 Average. Average speakers, camera, battery, handling.
Now, before anyone gets upset about this and say I am not this phones target audience, I will tell you I am. I like to tinkerer. On day one, I had the bootloader unlocked and the device rooted. Granted, this is probably about as far as I will go in terms of modifications to the device, it is nice to have a clean device. No bloatware shoved down my throat that needs updated even though I don't use it. Software that I cannot disable or remove or use. Software that slows the device down, uses up battery and gets in the way. In this way, the Nexus 5 is just what I wanted.
A snappy zippy device that is not locked down, or "leased" from the carrier and or manufacturer of the hardware.
I would actually take touchwiz on this thing for the use of the s pen and possibly multiwindow (though I would prefer floating apps) on the nexus 5 if that was possible. Yes, I would take this, provided samsung kept its bloat off the device. Chat on, samsung hub and other junk can stay off.
I would not mind a larger device. A 5.5 inch nexus 5 would be awesome. But I am digressing a bit.
The long and short of it, the Nexus 5, to me, as is, is an average device. And I guess that is okay, but its kind of sad at the same time. The camera app and volume could possibly be tweaked better with some software. The battery, well, as I said, I have the charging cable and a mycharge stick.
In the mean time, the N5 has my usual number, and the note II, I have taken the sim card out of my sisters SIII and using that more for other stuff while at work, like listening to music, social media and so one. The N5 is mostly a phone I guess.
