You can start by rebooting the router - remove and reinsert the battery on your device - check inside your device's support forum for some responses from the other users of the same device.
Wi-Fi problems are what I call the unknown - it seems like it has a mind of its own. Occasionally, it will come back on without much effort...other times you might need to do some troubleshooting.
Good luck and thanks for joining the community. ))
