In Mystique 2 ,you use the touchscreen for looking, and the pad for moving.
However on a Legend, which has a optical trackpad, doesn't work like a actual trackball; where on a trackball it registers a constant direction input when you keep your finger pushing on the trackball, you can move around the rooms quite smoothly.
D; but on an optical trackpad, it registers the direction only during your "swipe" across the pad. So for me to walk across a room, I have to swipe countless times, one step each swipe....
Is there a way to use the controls like Mystique 1 with the arrows onscreen?
