Greetings --
Been using my Nexus 7 tablet for 3-4 weeks now, with no major issues, except...some 'flakiness' in terms of connecting it to a PC (running, say, Windows 7 Home Premium) as a USB device. Several questions related to this theme:
1\ tablet does not show up on the PC as a USB device if I connect it when tablet is powered down. It only shows up if I connect it powered on.
q: is this normal? If so, it is the only USB-device (out of *many* I own) that needs to be 'turned on' in order to be seen/mounted by the computer
2\ if I connect when the tablet is powered on, shows up as a 'portable device', not as a USB device. I'm sure because it is a MTP device by default. Fine - easy enough to access the device, and copy various files from PC -> tablet. The issue I'm having is with 'unmounting' the tablet. Since it is not showing up as a 'typical USB device', I can't right-click and safely disconnect the tablet from the PC. In a bit of reading, it seems that all I need to do is simply unplug the table from the PC. OK, easy enought to do 'mechanically', but most of the time when I do this, the table get's 'locked up'. It's on, but the screen stops responding to anything. I can 'get the tablet back' only by doing a hard power-down (i.e., hold power-button down for 10-15 seconds).
q: again, this can't be 'normal' - what is the preferred way to disconnect the tablet from the PC? In all my years of working with a *lot* of USB devices, the N7 is the only device I have which has this little 'issue'.
Thanks much in advance...
