Help N7 Speaker Crackling/Popping
Eyedes
As the title suggests, I picked up my N7 from Gamestop yesterday and have been like a giddy school girl playing with it. However, the speaker has a cracking/popping sound that seems to usually happen when bass is playing (Transformers had alot of popping...) Anyone have a similar issue or do I just have a busted speaker? I really don't want to send my toy off after just getting it and have no idea when I'd get another. :(
Thank you for any opinions and input! :D
Mind sounds fine, I heard no crackling. I would bring it in and exchange it while you can.
Good luck!
Thanks for the reply! Unfortunately, mine was the last one in the shop I reserved it at. I'll have to look into other stores in the area.
Eyedes, spongeworthy, viveksaini, welcome to AndroidForums! Sorry it took so long to welcome you.
It's a bummer all you folks are having issues (grandhighpuba and meckert too). I'd suggest getting in touch with Google (Nexus Help) and see if they'll send you a replacement unit. There's a phone number on the linked page. Just set aside some time because you'll likely be on hold for a while.
Thanks richsz.
When I have some spare time I'll give then a call and see what they say.
I'll get back to everyone with what I find out
Mine was really bad with the crackling and popping. After giving up twice with hour long waits on the phone too Google, I popped the back off with a knife and sellotape some cotton balls to the speakers, it worked...
I'm having the same issues. I'm got mine from gamestop, hadn't really messed with the sound much, but when i first heard the default notification go off, it sounded horrible. So i played around with the music and it sounded like the speaker had blown. So i called Gamestop and they ordered me a replacement. Just playing the wait game now.
