Help N910T will not get GPS fix
MDReptile
Hey guys, I'm pulling my hairs out on this problem I am getting with my note 4.
Long story short - I cannot get a GPS fix (to even a single sat) with my N910T.
The longer version:
This thing had a cracked screen - but worked great before that (no GPS problems) and I used it a good year before breaking it. So I bought a N910A (ATT) note 4 to use the screen to fix my trusty note.
I gutted both phones, and put my N910T motherboard in the N910A's frame, with the screen still attached to the frame. I kept the N910A's USB daughterboard (with the charging port) because in the research I did, it seemed basically identical to the one from my broken screen frame, and I knew it would be tricky to get that out and into the new one without busting the new glass or destroying the flex cables.
So after some trouble with the S pen not working initially (the cable didn't press in fully, had to stick paper behind the flex cable and it went in properly) I was able to get the phone up and running again, and all features seemed to work great again.
However - I noticed after a couple days that the GPS was super spotty, so bad it was mostly unusable. I noticed that AGPS was on and it was using wifi and mobile data to help get a fix, so I turned it to GPS only mode. In GPS only mode the phone gets not signal whatsoever, no matter where I am.
I tried the simple fixes many recommend online, one which is to try tightening the screws a bit, and in fact, as this process continued I opened and closed up the phone several times, making sure to carefully but tightly screw all the screws back into place. That didn't help. I also tried making sure the compass calibration was good - and it made no difference. And I even factory reset to make sure there were no issues with installed apps or anything like that.
I got to thinking, perhaps its a issue with the small bendable pins that press from the motherboard into the mid-frame not making good contact, so I tore the phone down a couple more times, slightly bent out - very carefully - all the pins that press into the mid-frame to make them all have a solid contact, and even tried to get any corrosion or debris from the pads on the mid-frame. I even made sure there was contact for those little ones alone the sides of the phone which seem to have something to do with the buttons rather than what I'm dealing with.
Still no luck, so I tried doing a NV rebuild, which I read might solve getting 0 sat fixes, and discovered my phone wouldn't let me into that menu of the service options, so I had to install root and then do it through shortcut master instead. Once I finally was able to get to the menu and run the NV rebuild.... nothing changed.
I tried TopNTP and that made no change, so I reverted to default gps config.
Here is what I see when I run GPS Test:
So I am fresh outta ideas, and I'm thinking that A) that ATT USB daughterboard actually plays a part in GPS somehow and I need to take my TMO one out of the old phone and put it in the new frame and screen.... or B) Something is damaged on my motherboard.... or C) Somebody out there has a better solution
Any ideas, experiences of what worked are all appreciated!
Props to you for all the efforts you have done to keep your Note 4 alive and kicking. Reading through your description the only thing I'm able to suggest is take a look at the GPS antenna. If you were getting some kind of GPS fix while using WiFi & mobile data but not GPS on its own, I have to wonder if the antenna is damaged or it's just a matter of re-seating the connector.
If you're already aware of its location, ignore the following but I'm making a very tenuous assumption its in the upper left corner (when viewed back side up). Doing a casual search I didn't find anything definitive but with a Note 3 and a Note 5 that's the general location.
http://visihow.com/Know_the_Layout_and_Parts_of_Samsung_Galaxy_Note_3
https://allaboutgalaxynote.com/galaxy-note-5-how-to-guide/galaxy-note-5-layout/
I found a layout marking all the components on the note 4 board, and it showed that under the SD card slot, is a GPS chip. I figure that makes those two spring connectors near the vibrator the connections to the GPS antenna - but as a precaution I've propped up all of them slightly to get better contact. I tried making the contacts on the mid frame cleaner too, and still end up with the same result.
Really is a bummer.
Fyi here are the shots I used for reference:
Wow, Props Brother for all that your doing,
I have to wonder , Has the phone had any major software updates lately?
I ask because sometimes drivers get messed up... in firmware updates.
