Nabi2 -- soft or hard bricked?
rascle53
Heres wha i have done and my problem, sure hope theres some help an i havent broken it. Since FuHu has removed the updates i decided to give it a whirl myself. I read and read on the nabi2 and differant ways to update, but none worked. Somehow i deleted the OS, but i figured no problem and found the xda site for the nabi2 stuff. I was able to install twrp 2.2.2, it wouldnt read the micros sd card, i up graded the twrp to 2.8 version, everythig semed to work except the "slide button". Back to the drawing board. I down loaded twrp 2.6 for the nabi2 and installed. Have no idea what went wrong, but now, i fire up the nabi2, go into recovery kernal ( without being plugged into the pc ) it just sits there, when i plug the usb cable into nabi2 then the laptop, it automatically connects to the driver, and goes to a screen that has,,
bootloader
continue
reboot-bootloader
reboot
power off
now if i press the vol - again it goes to a screen....
boot normally
fastboot protocol
recovery kernal
forced recovery
it just keep fliping back and forth betwen thos 2 screens,it shows connected on my laptop,but try to load anything and it says no device connected..
Truley baffeled,, any help is appreciated
Thank you
Rascle
