Do you mean a car mount dock? or something with an additional micro-usb connector built in? For a mount dock you can check out a ton of my reviews in the sticky at the top of the thread, though my recommendation is for Arkon mounts. For something with a built-in connector, you can try iBolt mounts, but personally I'm against any of those docks because it puts a huge wear'n'tear on your micro-usb connector. And typically they are design for a slim case.
