any luck i need the same thing i have been trying to fix my box for over a month i cant get it to happen the box works but wifi is broke ive watched 100s of YouTube videos and none of them help I've got the same system you got but mine is a amlogic s905 stuck on 6.0.1 firmware
Try dowloading this: http://www.mediafire.com/file/74li43q4m8wicm9/aml_upgrade_package_MXQ805.7z/file
Extract it using WinRAR or 7Zip and download: http://freaktab.org/f6527047df361c15
Now after they are both downloaded unzip the one from freaktab and double click the program, the program will be in Chinese. Go to the top bar and click the second option and change it to English now select your SD (maybe format it before you do anything) and flash the aml_upgrade_package_MXQ805.img (which you should of gotten from the .7z file from mediafire) then click the "Make" button and the bottom of the program. After the file flashes to the SD Card, put the SD Card into MXQ Box and then get a toothpick and put it through the AV port until you feel or hear a button click, then keep holding the toothpick in there while applying power, keep holding the toothpick until a "Upgrading" Screen comes up on your TV or Monitor, wait 4-5 minutes then the MXQ Box will reboot, do the initial setup and then when you get to a screen that says "Android Launcher" or "MediaBox Launcher" click MediaBox Launcher and then Always (If you you can do "Just Once" but then you will have to select it every time)
Well I will do just that when I fix my device I flashed "Aidans ROM" to my box now it gets stuck on a screen that just says Android tv Aidans ROM 7.4 and it will not even boot into recovery mode
