Need a lil help guys...
acostello
I want to change my theme, but I dont know what kind of default themes i can get from the market. Do I go there, or should I download them from another source? Just a little of basic help would be great! Thanks!
Try Pandahome (if you have not already) It is a free home replacement app available on the android market, and from my experience with it, it works very well. It also give you the ability to preview the themes for it before you apply by clicking on the icon on the left side of the screen. You can mix and match icon sets, themes and backgrounds, and also dl new icon packs from the market. The side docks are a nice touch too, allowing you to have more apps accessable to you quicker than most apps.
Hope that helps.
I found PandaHome to be very limited in theme selection and extremely slow in pulling up screen shots before installing.
It could be me though....
I like Open Home and there's a decent amount of themes. I am still learning so I am sure some of the other folks here will have more info.
