need a new charger fast!plz help
MKSaxena
i have a spice mi 425 mobile with android 2.3.6 and i bought it a year ago and it came with a usb charger but somehow i broke that usb wire from inside and now it is not working....it used to charge my 2000 mah battery really fast and i had a nice battery backup but since it broke,i started using a random charger which was lying in my home with same jack and it is so shitty that it takes a long time to charge my phone and also reduced my battery backup
so i need help to buy a new powerful charger for it
which one should i buy?and how to find the right one in the stores?
and btw what are external usb chargers?can i use one?how to use it?how it works?
i'm assuming external usb chargers are like portable battery packs from mophie, new trent, or anker (google them). In general, it isn't the wire that determines the charging capacity/speed; it is the actual charger's output itself (1A vs 2.1A). I'm gonna take a stab in the dark and say your old charger w/ the frayed wire supplied 2.1A and now the one you found is a slow 1A charger. (NOTE: the physical wall charger itself, not the wire).
yeah u r right
i have ordered usb data cable for my phone and i also founded the original charger box and one more like that
the original one says,input: 100-300V-50/60Hz 0.15A
output: DC5V---600mA
and the extra one i founded says,input: 100-380V-50/60Hz 0.3A
output: 5.0 V---600mA
which one should i use to charge the phone?
both are power adapters and i can plug them in wall switch and i can insert my new usb into them and another end to my phone to chargre....which one should i use?
Look for a HTC charger with 5V/1A output. Its USB connector is modified for to charge your phone rapidly with a standard USB cable.
This feature is rare with generic chargers.
Harry
