Tigatron
Android Expert
Need the update device apk
I tapped delete instead of disable.
Also need to know what folder it belongs in.
This app make update prl, update profile, and some other update stuff work.
If it makes a difference im on boost.
Resolved:
If you lose the ability to do updates as I did you need LGDMSClient.apk & LGDMSClient.odex
For them to function.
They should be in the system/app folder
https://www.dropbox.com/s/k5pmoszjmhoi3zi/fix Prl update.zip
Resolved:
