Help need better OS
nazmul420
a have a clone i phone 7 plus whose model number is
iPhone ML7G2CH/A. any one can help me to install better OS in this phone??
I presume this iPhone isn't running iOS and it's some flavour of Android on it, that's skinned and modified to look like iOS?
Trouble with clones and knock-offs from unknown manufacturers, there's no good useful information available for them that ROM developers can use. Also I suspect it's using some cheap Mediatek SoC, which makes any ROM development pretty much impossible.
so is there any other way to update it to get rid of disturbing adds..???
Is it lock-screen and/or dialler ads that are basically baked into it? Frankly without root and hacking/modifying the system, there's likely nothing can be done. And as there's no definitive good developer information about this device, there's no chance of doing that. You could try NoRoot Firewall, no promises though. https://play.google.com/store/apps/details?id=app.greyshirts.firewall&hl=en
I did see a reports of something similar the other day with a cheap fake Samsung Galaxy S8, a Bluboo S8. Which was running something called 360OS, a Chinese version of Android that's monetized with adware and spyware. http://www.360os.com/
I suspect it's this or something similar is what your iPhone clone is running.
Any chance of returning it for a refund?
