Need for speed Most Wanted save location
onpointG35
Can anyone tell me where I find the location where this game is saved. I looked in Android, Data com.ea.nfs13 but the date doesn't add up, the last update to that folder was dec of last year but I played a couple days ago.
Any assistance is welcome
thanks
Most oft he time you can't find the save file, and have to do a backup instead to retrieve said file. In most cases, the save files are located in the system partition so you will need to be rooted to extract them. Or you can use Carbon to do it if you're non-rooted (which I suppose you are).
Thanks for your insight, I'll try carbon my tablet is not rooted only my cell.
