BTK-appl3killa
hello all and thanks for reading, the reason why I'm posting this thread is because I'm going to build my own computer (which i have never done before) and would like to get some help if possible by someone that has done this before
this is what the computer will include in it:
MSI 785GTM-E45 Motherboard
AMD Phenom X4 9750 Quad Core Processor
Masscool 5W1081F1M3 CPU Fan
Lite-On Internal 24X DVD Writer
Crucial 2048MB PC6400 DDR2 Memory x2
Seagate Barracuda 1TB Low Power Hard Drive
PowerUp ATX Black Mid-Tower Case with Power Supply
You need to make sure you get the motherboard standoffs in properly to keep the motherboard from shorting out on the case. And as I said before, watch your hands in that case. The reviews for it report sharp edges in there that will slice your hands very easily. Just take your time and you will be fine.
