Root Need HELP. Barnacle wifi tether.
currently i am using take 5 rom and i dont know how to use barnacle wifi tether.
my laptop detects its signal and gets connected but the browser says it doesn't have internet connection.
i also check the client section of barnacle, it says no client.
laptop shows it is connected but barnacle says no client.
what should i do to use it?
do i have to change settings?
please help.
thank you.
thank you very much.
it worked really well.
i didn't know how to adb and things.
i just copied rtecdc.bin file to system/etc/ folder and overwrote it with using root explorer.
