Try going into the Apps menu in your Settings, find and open the Viber app entry, and in the Open by default option tap on the 'Clear Defaults' button. That should clear the Viber app from being the default phone call app. If you then launch the Phone app and there's a prompt to make it the default be sure to follow through accordingly.
