I'm sorry if this question sounds familiar, but this has me baffled.
I have a rooted t-mobile variant of the stylo with 5.1.1.
I'm trying to edit my lgsystemui.apk file. All I want to do is modify or remove 2 files. stat_sys_battery_light.png
If I can't remove them I at least want to make them clear/invisible.
I have searched and found many posts and articles saying to use "apk editor", "ninjamorph", "zip signer", etc.
In short none have worked (successfully).
I do not have a computer or access to one.
Is there something I can use to change these files and replace the stock lgsyatemui.apk file, or at least something that works like the xposed battery themer?
