Need help finding the correct wallpaper size for my tablet..
Orion
Android Expert
I just recently purchased the LG G Pad 10.1. It's 1280x800. I can never get the correct wallpaper resolution for this tablet. It always comes out pixelated or zoomed in. Any ideas? Thanks.
Do you have a PC? Probably the easiest way is to scale your desired wallpaper image to the appropriate size, i.e. 1280x800, in GIMP or some other photo editor. You may even be able to scale the image on the the device itself using something like Image Editor.
