I bought two Stylos for myself and my wife. My wife's Stylo had GPS problem. It had trouble getting accurate position making Map, Navigation, Local Search useless.
I've tried installing different ROMs (Stock Tmo, Stock Metro, CM12 with GPS lock, Katana, upgrade to MM) but nothing worked so I ended up issuing LG Warranty service.
LG G Stylo has 1 year warranty on it. If it truly is phone problem like mine. Issue a Warranty ticket and get it repaired.
The one I got GPS Warranty service worked for few weeks then GPS went bad again... I am issuing 2nd warranty on this phone. This time I am going to demand replace / upgrade instead of fixing.
I've seen couple of GPS issue posts on this phone, seems like they have bad batch or something...?
On the back of the Stylo battery door is a copper contact going to a black strip. This is the NFS/GPS antenna. You may want to try making sure the contacts are touching (battery door is snug).
