ROMs Need help having issues with my ctOS ROM!
  • Start date Start date
D
Deleted User
Guest
Well here"s my problem i have a kernel that i setup and its currently in nightly but my OS would runs other kernels perfectly but if i change my kernel to add someones elses kernel instead of mine is their something im doing wrong because everytime i test a different kernel bluetooth fails to turn on, but if i kept my original kernel i built bluetooth works fine
Heres a name of code in my kernel that i implemented for security i call it ctOS Firewall this basically does is protects the user from malware and if malware infects something the kernel locks that feature till the user can fix the issues, also its supposed to notify you upon OS has been compromised etc and notify you that it has disabled that specific feature but no notification this is a new system im testing to protect users data im really into keeping my fans/user safe from theives?
