Need help identifying app
Anyone know what app these two are? One is blue background white M and the other is light blue with a white Y. Thanks !
Try Bixby, it is preinstalled on Androids
Not on Androids - only Samsungs. And I suspect it won't be able to answer this question (I'm sure a Google reverse image search wouldn't, and Bixby isn't going to do better).
No, I don't recognise them, but there are literally millions of apps so you'll be lucky if someone familiarr with those precise icons sees the photo. The best way would probably be to ask the owner of the phone.
