Need help in coding
namdaemun
I've just started learning to build android apps a week ago and now I'm playing with MediaPlayer class.
I'm building an app that will play a sound once the user clicks the button
here's my code :
package com.jason.shootemup;
import java.util.Random;
import android.app.Activity;
import android.media.MediaPlayer;
import android.os.Bundle;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Toast;
public class game extends Activity implements OnClickListener {
View shoot, reload;
int bullet = 5;
public static final Random r = new Random();
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.gun);
shoot = findViewById (R.id.shoot);
reload = findViewById (R.id.reload);
reload.setVisibility(2);
shoot.setOnClickListener (this);
@Override
public void onClick(View v) {
switch (v.getId()) {
case R.id.shoot :
shoot_sequence ();
break;
case R.id.reload :
Toast.makeText(this, "Reload !!", 10);
reload_sequence();
break;
// TODO Auto-generated method stub
private void shoot_sequence() {
if (bullet > 0) {
play_shoot_sound ();
Toast.makeText(this, bullet+" left !!", 10);
bullet = bullet - 1;
else {
reload.setVisibility(0);
shoot.setVisibility(2);
private void play_shoot_sound() {
MediaPlayer mp = MediaPlayer.create(this, R.raw.shoot);
mp.start();
mp.stop();
mp.release();
private void reload_sequence() {
play_reload_sound();
bullet = r.nextInt(4) + 1;
shoot.setVisibility(0);
private void play_reload_sound() {
MediaPlayer mp = MediaPlayer.create(this, R.raw.reload);
mp.start();
mp.stop();
mp.release();
It was compiled successfully and worked on my emulator. but when I installed it on my motorola droid, the sound won't come out. I've set the volume to max, but nothing happens. I think it's probably because of the source code
I'll be very grateful if you can point out my mistakes in my source code
THX for the help...^^ :D:D:D
