Apps Need help in developing an android app
Sachin A
Hello,
I am new to android development. I want to develop an android app which will register users for an event. I am not sure where I should store names. Can I use MS access database? can android app add/edit/delete data from MS access? If this is not the correct approach, suggest an alternative solution to this. Supposed my app is being used by multiple users, they should be able to connect to the same database. Can I keep my database on google drive? I am not sure how multiple users will access the same database? In short, when multiple users start using my app and register their names for an event, how it will be added to common database? I don't want to ask them for login etc.
Appreciate any help or guidance for my first application development.
