I have a question on moving my nandroid backups , ( TWRP folder and files ) to my extSD card through Root Explorer file manager. I did the SD card fix for kitkat and it was successful. I was able to get Titanium Backup Pro to backup to the extSD card and move the files over but when I try to move my TWRP folder I get the KitKat error message in Root Explorer . Do I need to change something in the mount R/O R/W setting under root ? If I use ES file explorer it will move the folder but not the files . I have root access granted to both file managers . Any advice would be much appreciated, Thanks !
