need help on apps
iffy01
hi,i got samsung galaxy ace s5830.i had 2gb sd card,which had few apps n now memory is full so cant download anymore.so i bought new 16gb sd card,now after donloaded few apps its say dat 'there is insufficient space on the device'.still i got 14gb left.so plzzz cn u sort the problem thnxxx
Apps data is placed on you device memory unless you are rooted.
Your device has ~150MB of memory so you may want to pay attention to what apps you are using.
* Remove unused or memory hungry apps.
* Clear unused data using Cosmos AppLocker + JunkCleaner
If you want to root your phone, this is another story... You will be able to store apps on your sdcard.
