Need help plzzz !! Galaxy s2
weiry
Hi, i have a galaxy s2, i have had it for around a month now and it is great,
unfortunetly it is now doing this annoying thing where it thinks it is constantly charging and uncharging, the best way to describe this ... is probably like connecting and unconnecting the charger, it keeps bleeping ... even when im on the fone ... it is really really annoying and it seems to be draining the battery aswell. if anyone has any ideas it would be great :). Also i have previously downloaded 'juiceoffender' to completely drain the battery and then fully re-charge it, which didn't work. So i then done a factory reset and still not, fixed.
Hello weiry and welcome to Android Forums. Our S2 discussion areas are set up per carrier. Each carrier has a bit different version of the the S2. If you could let us know who your provider is... we'll gladly move your thread into it's discussion area where it will receive attention from the people who know your phone best.
Each type has its own model number.
The i9100 is international. If your forum names don't include the model numbers in the title, consider adding them
