Root Need help removing system apps
rlattin24
30
5
Hey guys I rooted this phone with KingRoot so I do have Root Access.
I am trying to remove some apps I do not use and are just taking up space.
I have Rom Tool Box Pro and I should be able to uninstall the apps with that regardless if they're system apps or not but for whatever reason it won't actually remove the app.
I've tried using RootBrowser and checked the folder system/app to manually delete the app I'm searching for but it there not there either.
I'm trying to remove apps like Google+, Chrome, Hangouts, Drive, Play Movies, Books, Stuff like that.
If anyone has any suggestions I'd greatly appreciate it, Thank You. :)
BEST TECH IN 2023
Smartphones
