I have a Huawei Honor Holly (Hol-U19) which I recently rooted. I then attempted to install a custom ROM and ClockworkMod, but somehow it all ended in me not being able (as far as I know) to access recovery mode. Also, when I do a factory reset from the Settings app, that doesn't actually do anything - I don't know if my attempt to do so screwed something up or not.
I have an SD card connected, and on it are, among other things, folders named "clockworkmod" (containing two files: ".nomedia" and ".settings") and "Kingroot" (with one folder "user" containing files "e_config" and "xda_config.dat").
Also, the phone doesn't show up in Windows Explorer (whether USB debugging is on or not or the SD card is inserted or not).
The gist of it is that I don't know how to install the stock ROM to "reset" it back to its original "form", and I really need some help on this. If you need any other specific information, I'll try my best to give it to you.
