S Spastik Lurker Jan 20, 2015 #1 I have an LG L70 that is seemingly impossible to root. I am not tech savvy so please use simple terms and bright colored crayons ;-)
N nono non Newbie Jan 20, 2015 #2 is the lg l70 from metro pcs? if so go to my guide: http://androidforums.com/threads/make-sd-into-internal-mem-detailed-ms323.895206/ skip to the "rooting your phone" section.
J JesseKnows Member Jan 23, 2015 #4 orneliu said: Purpledrake lite work for me. Click to expand... Was that with the "C" firmware?
O orneliu Lurker Jan 25, 2015 #5 JesseKnows said: Was that with the "C" firmware? Click to expand... Yes.
mrrom Android Enthusiast Feb 6, 2015 #6 I can't Root my device. I tried both purple drake and towel root and no luck
