Help Need help rooting my phone!
Fatality
I have android 4.1.2 installed on my Galaxy Grand quattro.
I first rooted using mobogenie. Root was successful but superuser failed to gain root access while updating binary! Can someone tell me how to fix it?
I also tried rooting with Poot but it showed up error 18! WTH!
I tried using framaroot. I opened it up and tried using gandalf exploit. But nothing happened.
Please help me to root from any of the methods and gain superuser access. :confused:
Thanks :rolleyes:
Thanks :rolleyes:
Hello bro just install clockwork recovery and then flash the root zip then you're done !
I've rooted mine by this method :)
