Been trying to root my phone now for few days following YouTube videos to no avail. Was wondering if anyone can help me.
Android Version: 4.4.4. Verizon
Build Number: KTU84P.G900VVRU1ANK2
Kernel Version: 3.4.0
I'm totally clueless when it comes to anything tech! Would appreciate any input from anyone. Thanks in advance!
Hello and welcome to Android Forums
ChicagoboyRN!
I would guess that your phone has been rooted at some time in the past as it is on the very, very, old Android 4.4.4, NK2, firmware and should have been forcefully updated by now to Android 6.0.1, unless it was rooted.
In a nutshell, to root the Verizon NK2 firmware, you need to replace the kernel with the older
NCG kernel using
Odin, and then use
TowelRoot to root and then you need to flash the
NK2 kernel via Odin and install
SuperSU. Finally, check you are rooted using
Root Checker. All this is shown in the video below...
WARNING: Rooting is for
competent users and can, "brick", your phone if carried out improperly.
Backup all your user data, prior to rooting. The key to rooting is... read, read, read, Google search, Google search, Google search.
In case of problems with flashing and rooting, here is the stock Verizon firmware for NK2 that you can flash to your phone via Odin by following the instructions and video contained in the links of
#1.11 of
42 Galaxy S5 models - Dummies Guide. This will at least, return you to unrooted stock Verizon firmware.
Model SM-G900V
Model name GALAXY S5
Country USA (Verizon)
Version Android 4.4.4
Changelist 3196895
Build date Mon, 17 Nov 2014 10:33:49 +0000
Security Patch Level N/A
Product code VZW
PDA G900VVRU1ANK2
CSC G900VVZW1ANK2
ironass motto... "Flash in haste... repent at leisure!"
