Hi, i have a galaxy s2, i have had it for around a month now and it is great,
unfortunetly it is now doing this annoying thing where it thinks it is constantly charging and uncharging, the best way to describe this ... is probably like connecting and unconnecting the charger, it keeps bleeping ... even when im on the fone ... it is really really annoying and it seems to be draining the battery aswell. if anyone has any ideas it would be great
. Also i have previously downloaded 'juiceoffender' to completely drain the battery and then fully re-charge it, which didn't work. So i then done a factory reset and still not, fixed.
*** i think it is a 9100 if that helps :s
. Also i have previously downloaded 'juiceoffender' to completely drain the battery and then fully re-charge it, which didn't work. So i then done a factory reset and still not, fixed. *** i think it is a 9100 if that helps :s
