Ahmed Mabrouk25
Hello everybody
My Mobile is Samsung Galaxy Note 2 n7100 16G
Please I need help with my device which completely dead because of failed root.
Before I start root it was freezing on the 1st logo shows GALAXY NOTE 2 etc and don't continue opening at all.
I read a lot about the problem and reached that I have to install a new rom.
I tried that downloading a Firmware from sammobile.com website and tried to install it by Odin but it failed at the middle of process.
I tried another Firmware from another famous website like sammobile.com but it failed at the middle of process too.
I read that there is another way to install my Firmware by using Samsung Kies so I tried this way but it failed also at the middle of process.
at this point my device was at downloading mode as it required while you install the Firmware.
I unplugged the device from USB cable then I switched it off and tried to switch it on again as I did before with all the above points but it didn't switched on again.
I thought it maybe by mobile battery but after I went to the shop it seems that the battery is pretty good.
after I read many many articles about the problem it seems that I need the scatter file of my mobile model
to be able to install a new Firmware again.
Is there anyone who have the same mobile model can help me with this issue by giving me the scatter file of his own mobile?
Thanks in advance.
Thanks in advance.
