ok, sorry for the delay, thank you for tuning back in, heres all the info mediainfo gives me...
Format : MPEG-4
Format profile : 3GPP Media Release 4
Codec ID : 3gp4
File size : 10.3 MiB
Duration : 24s 960ms
Overall bit rate : 3 446 Kbps
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
Baseline@L3.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=30
Muxing mode : Container
profile=Unknown@12.3
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 24s 865ms
Bit rate mode : Variable
Bit rate : 3 394 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 3:2
Frame rate mode : Variable
Frame rate : 29.479 fps
Minimum frame rate : 18.182 fps
Maximum frame rate : 33.333 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.333
Stream size : 10.1 MiB (98%)
Language : English
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Bit rate : 62.2 Kbps
Maximum bit rate : 64.4 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 16.0 KHz
Stream size : 182 KiB (2%)
Language : English
