Root Need help [urgent] phone stuck in boot screen
h4x0rz
Okay, well I rooted my Pantech Breakout about 2 months ago and everything was fine. I installed a rom about a week ago. I re-installed today and got an error while I was in recovery and shut off my phone. Turned it back on and it wouldn't work. I tried to re-installed the rom again and it installed fine, but phone still doesn't turn on.
PLEASE HELP
Try to follow these steps.
1. Go back into Recovery
2. Wipe Data and Cache
3. Reflash ROM
4. Wipe Data and Cache (again)
5. Reboot
Let me know if it doesn't work
3. Reflash ROM
5. Reboot
question: when you say "reflash ROM" the only option i have besides delete data, cache or reboot is "update from sd card".... is that where i would be "re-flashing"
Not really.
You would select "install from sd card"
Also, I'm glad you got helped on the other thread. My internet is having issues.
