justjerry
Hi everyone! I'm brand new to the Android community as I just upgraded from a BlackBerry Curve to the HTC EVO 4G - and love it!
I've been tinkering with it for a couple of days and decided on using Launcher Pro. I didn't really know what this was when I installed it - only that it would add some UI features (more screens, etc.). However, still being a newbie at customizing my EVO's UI - I thought I'd post here for some help.
First, could someone clarify the difference between an app, shortcut & widget?
1) After switching to Launcher Pro, I don't seem to be able to add widgets I had under the standard HTC launcher - like favorite contacts (a vertical widget strip in which you can place contact favorites' pics & dial from). Also missing are a digital clock and weather widget. Is there anyway to use the HTC widget with Launcher Pro? If not, where would you suggest I find some good ones?
2) I've downloaded Launcher Pro Icons - from the app store. I was hoping to find some 3D app icons like these:
but unfortunately none like these were included. Can anyone tell me where I can get 3D icons like these for my apps? WOuld I just download and icon set and then activate it -or would I have to edit each individual app to change it to show a new icon, etc?
I'd also like more dock designs.
I'm really looking to customize my UI - and the more options the better. I tried ADW Launcher and found it to be confusing. I've thought about trying GoLauncher too.
Anyway, I'd really appreciate it if you guys could help me out!
Thanks!!
Jerry
Thanks!!
Jerry
