my phone is a Nexus 5 16gb, and has no sd slot, so I am looking for a device to store recorded video externally. I have tried the StickMount with OTG flash disk, but it is unstable, I can't charge the phone, even with Y cable the charge is very low, and still drains the battery and the hassle with cables is just too much to handle (other truck every day.....)
Now I know there are MANY wifi storages, but..... Please keep reading...
I'm using it as a dashcam recorder, so the program/app (like DailyRoads Voyager) records clips of, say, 5 minutes, and stores them to a folder.
What wifi disk/hdd/flash reader/writer do I need to use, to make it possible to write DIRECTLY from any APP to the wifi device's folder? In other words, it should behave and used as if it were internal memory......
I've asked Kingston, they have nothing that works that way.
I HAVE to be sure, I can not use it if I can only browse the wifi SD card with ONLY one specific dedicated app, it needs to add a map to the phone's system that any another app is able to use for DIRECT storage (maybe needs a driver?).
ALL tips / hints welcome!!
